Home / Contemporary timepieces / 3536-02 braclet link - stuck pin
  2. Contemporary timepieces
  • forum 2 replies
  • last reply by Matt T 14 May 2019
    Matt T
    12 May 2019, 5:22 a.m. 12 May 2019, 5:22 a.m.
    I just aquired a 2001 3526-02 in near mint shape here in Tokyo. I removed one
    link and found that the push-pn would not re-extend once pushed in. I am now
    soaking the link on WD40 t try tp free it up. Any advice? Fortunately I did
    not need this link to wear the watch. This is my third and favorite IWC (3255
    & 3719).
    14 May 2019, 2:38 p.m. 14 May 2019, 2:38 p.m.
    That is indeed the main problem of that links system.
    I had once the same problem and was able to solve it with heat and cooling
    spray.
    Heating up the link with a gas lighter and then dropping some drops from a
    cooling spray can onto the pin. I continued this procedure some times until
    the pin snapped into the right position again.
    Good luck
    Matt T
    14 May 2019, 2:45 p.m. 14 May 2019, 2:45 p.m.
    Thanks I will try that. Appreciate the reply.
