  • Big Pilot and Vertical Clutch
  • forum 3 replies
  • last reply by MarkFleminger 13 Mar 2020
    Jack Straw
    Graduate 53 posts
    13 Mar 2020, 12:05 p.m. 13 Mar 2020, 12:05 p.m.
    Hi, does anyone know if the big pilot, specifically the 5002, has a vertical
    clutch coupling? I ask because my local AD mentioned this as a reason
    servicing would be expensive, but from researching this it looks like vertical
    clutch is mostly associated with chronographs.
    Any help is appreciated.
    Master 3210 posts
    13 Mar 2020, 4:42 p.m. 13 Mar 2020, 4:42 p.m.
    Vertical Clutch will only be found in a chronograph movement.
    This AD obviously doesn't know the difference between a chronograph and
    chronometer!!!!
    Jack Straw
    Graduate 53 posts
    13 Mar 2020, 5:17 p.m. 13 Mar 2020, 5:17 p.m.
    The person also referenced the double barrel which to my knowledge the 5002 is
    a single barrel.
    Master 3210 posts
    13 Mar 2020, 5:55 p.m. 13 Mar 2020, 5:55 p.m.
    Correct.
    Last Big Pilot Reference 5009 had single barrel and Cal 51111
    Big Pilot Ref 501001 received Double Barrel and Cal 52110 movement
