    1 Feb 2015, 3:38 p.m.
    The balances and the screws of these balances are different.
    • The balance of the C.67 has two incisions. The ring is not closed.
    • The balance of the C.952 is closed and the screws have no slots for a screwdriver.
    Presumably, the technical principle of these balances is different.
    What could be the technical reason for the different balance construction ?
    derjonk.de/lizard/c67-c952macro-1.jpg
    derjonk.de/lizard/c67-c952macro.jpg
  • 1 Feb 2015, 4:45 p.m.
    The c. 67 has an old style, bimetallic split balance, which was an early form of temperature compensation. You can read about that by clicking here.
    The cal. 952 has a more modern balance using Glycdur, a metal that handles temperature compensation. I'm unsure about the lack of screw heads, but some screws are adjusted using special wrenches rather than screwdrivers.
    1 Feb 2015, 5:53 p.m.
    Superb answer, thank you Michael.
    That clarifies it perfect.
    1 Feb 2015, 6:27 p.m.
    Thanks Michael.
    Walt Odets provides an excellent overview on the balance wheel, perfectly understandable for non-watchmakers.
