  • Ever seen the front side of a cal. 952 ?
  • forum 6 replies
  • last reply by HEBE 20 Aug 2019
    18 Aug 2019, 10:35 a.m. 18 Aug 2019, 10:35 a.m.
    Exellent decoration, no real need for a dial, that covers this view.
    18 Aug 2019, 11:45 a.m. 18 Aug 2019, 11:45 a.m.
    Haha, beautiful indeed Heiko! Thanks for sharing.
    Master 3202 posts
    18 Aug 2019, 9:30 p.m. 18 Aug 2019, 9:30 p.m.
    WOW Indeed beautiful
    19 Aug 2019, 6:41 p.m. 19 Aug 2019, 6:41 p.m.
    Thanks for your reactions on this uncommon PW.
    Moderator 3583 posts
    20 Aug 2019, 6:55 a.m. 20 Aug 2019, 6:55 a.m.
    "because we can" was once the answer to the question "why ?"
    Very nice indeed, thank you for showing.
    ADRIAN van der Meijden
    Master 2662 posts
    20 Aug 2019, 3:19 p.m. 20 Aug 2019, 3:19 p.m.
    Hi Heiko,
    How sure are you that this p.w. is original without a dial?
    After all, it is easy to mount the hands without the presence of a dial.
    It is just a press-on fit. Without a dial means more dust and dried oil in the
    movement or are you just kidding?
    The only p.w. that I know without a dial is the Scarabeus watch designed by
    Ernst Fuchs.
    Adrian.
    20 Aug 2019, 6:29 p.m. 20 Aug 2019, 6:29 p.m.
    Adrian, you are on the right track.
    I have some PW cases and I have a cal. 952 and I am thinking about mounting
    those items together ?!
    But as usual, I use Photoshop for an virtual draft, how my ideas would look in
    real.
    This draft is very similar to the reality, when I would decide to mount it.
    It is not bad, but I don´t have a final decision yet.
    So, it is not kidding, because it´s possible to realise it.
    But I will try another draft with a steel case and other hands, because that
    could be fit better as this first draft.
    Geste Gruße
    Heiko
