For the recent Press Conference in Schaffhausen, I wore my Portuguese Regulateur Tourbillon. After all, this is the year of the Portuguese and it is a nice watch. A few people at IWC asked me why I would travel with such a watch, and I explain that it really is my everyday watch. I probably wear it 80% of the time. Watches are meant to be worn and it’s held up fine. I’ve taken it on dozens of trips and through scores of airports.
That is, until the watch met its match at Terminal 5 at Heathrow in England. As I usually do, when passing through security I put my watch in my case so that there’s no metal to set off an alarm as I pass through the metal detector. So far, so good.
But when I put the watch back on my wrist and checked the time a few minutes later, I noticed that it was running about 15 minutes fast. I thought that I might have made a mistake and accidentally reset the time when winding the watch. So I reset the watch –and a few minutes later it was running another 5 minutes fast. Reset again –and again it was running fast.
When I finally landed I reset the watch and put it away for the night. In the morning it was running about 3 hours fast –ouch. I knew then that there was a problem, and was worried stiff that I’d have a $2000 tourbillon repair. Perhaps the watch got jostled and something awful happened.
More likely, I thought the watch might be magnetized –so I called Jack Freedman for advice. Right off the bat, he asked if I had been through any airport scanners. He then suggested I get the watch demagnetized. I asked if I could go a local Radio Shack store and buy something, and he suggested I go to a local watchmaker. I did –and in a 2 second swipe through the demagnetizer, the watch worked fine.
Whew! And beware of Heathrow, Terminal 5 –and least with watches without antimagnetic shielding.
Michael
The Culprits
The Victim
