  • Is 8541ES hand-wind?
  • last reply by pang HK 29 Apr 2024
    pang HK
    Apprentice 4 posts
    28 Apr 2024, 3:54 p.m. 28 Apr 2024, 3:54 p.m.
    I know this sounds a stupid question. But my 8541ES can be wound automatically, but it failed to be wound by hand. Is this normal?
    Moderator 3604 posts
    28 Apr 2024, 5:12 p.m. 28 Apr 2024, 5:12 p.m.
    Hello, no I bleieve that is not normal, should wwind by hand too.. Maybe time for a service.
    Andreas IWC likes this.
    pang HK
    Apprentice 4 posts
    29 Apr 2024, 12:05 a.m. 29 Apr 2024, 12:05 a.m.
    Thanks Tonny for the information. It is time for a full service.
    Insider 424 posts
    29 Apr 2024, 10:55 a.m. 29 Apr 2024, 10:55 a.m.
    Hi Pang,
    this sounds very strange.
    Can you set the hands by pulling the crown and operate it? If yes, the stem of the Crown is OK.
    Push the crown back in and turn int counterclockwise, You should hear a clicking voice vrom the sliding pinion that is slipping.
    If that is not the case the sliding pininon sems to be stuck. Then your watch should be taken care by a watchmaker.
    pang HK
    Apprentice 4 posts
    29 Apr 2024, 1:28 p.m. 29 Apr 2024, 1:28 p.m.
    HI Cromagnonman. Yes, the winding stem seems unable to "lock"/engage at the winding position. But it works well at the time-adjusting position.
