    29 May 2019, 2:26 p.m.
    This watch is a Caliber 83 which was produced from 1930 - 1947
    According to the number in the caseback, it was made in 1941
    If you give us the number on the movement, we can give a more accurate date.
    Is this a family heirloom?
    29 May 2019, 3:51 p.m.
    May I add this? The type of bracelet on the watch is a type that can damage
    the inside of the soft gold lugs. I recommend having a qualified watchmaker
    (or knowledgeable carefull hobbyist) remove the band from the watch head. Of
    course, if this is an heirloom piece that will not be worn, you may choose to
    leave the band connected to the watch.
    The serial number can be found just about where your thumb tip is in the last
    photo. It will be a six- or seven-digit number stamped into the lower plate
    between the balance wheel (with the screws on it) and the escape wheel bridge.
    29 May 2019, 11:20 p.m.
    Hey, thanks for fast answer. You helped me a lot and yes it is family
    heirloom. It was gift for my grandmother from her uncle. Then she gaves it to
    my father. Unfortunetly i cant check now the serial number becouse im at
    vacations. Do you know maybe what is the value of this watch also its a little
    bit dirty and demaged (whole mechanism is working fine but you can see under
    the glass that is dirty) so i want to restore it. Maybe you can tell me
    approximate price of that?
