  • IWC Yacht Club Chronograph
  • forum 7 replies
  • last reply by Robking 30 May 2025
    PeterSule
    2 Oct 2023, 12:06 p.m. 2 Oct 2023, 12:06 p.m.
    Dear All,
    Just found this Yacht Club Chronograph, could someone help me to identify, whether it is an original timepiece, a replica or a "LEGO" watch? It seems to have a Boutique Edition case (rubber coated), a Volvo Ocean Race carbon dial, but the problem starts at the caseback.... the engraving says: Edition 2011 One ouf of 1000, and the serial number cannot be found in IWC register....
    Any ideas?
    Thank you for Your comments,
    Peter
    Moderator 3596 posts
    4 Oct 2023, 6:28 p.m. 4 Oct 2023, 6:28 p.m.
    with that dial, it should be a titanium case, and not rubber coated, so I have my doubtd about this one
    4 Oct 2023, 10:09 p.m. 4 Oct 2023, 10:09 p.m.
    What Tonny says is true anyway, but I don't see the rubber coating on the case? Seems gold colour (which is also wrong!)?
    4 Oct 2023, 10:12 p.m. 4 Oct 2023, 10:12 p.m.
    What Tonny says is true anyway, but I don't see the rubber coating on the case? Seems more like gold colour, which is also wrong...
    Lyles
    Graduate 100 posts
    5 Oct 2023, 7:57 a.m. 5 Oct 2023, 7:57 a.m.
    A lot of doubts here. As Tonny and you already mentioned, the dial does not fit to the rubber coated case.
    The case back engraving is wrong on multiple levels, too. First, the typeface is wrong. Then, the Boutique edition (Ref. 390208) was limited to 250 and not 1000 pieces. "Edition 2011" is not engraved in the original version.
    I would stay away from this watch.
    PeterSule
    9 Oct 2023, 9:43 a.m. 9 Oct 2023, 9:43 a.m.
    Thank you Gentlemen for the answers, Yes it must be a "Lego" watch... The Case, movement and dial must be genuine parts, but the caseback is an aftermarket or replica one... Anyway it looks nice, but with this caseback it is a no-go.....
    Master 3265 posts
    9 Oct 2023, 4:49 p.m. 9 Oct 2023, 4:49 p.m.
    The rubber coating does not belong there. Maybe it was done afterwards. About the case number I can't say anything. Dial and bezel don't fit. Engraving of the original Volvo Ocean Racer (where the dial seems to be borrowed from) is different too. Better stay away!
    Robking
    Apprentice 5 posts
    30 May 2025, 2:06 p.m. 30 May 2025, 2:06 p.m.
    Hi áll !
    I found a very similar watch . The case number different only the last digit
    Back case description same
    Dial same !
    What do you think
