    2 Mar 2017, 10:31 p.m.
    I bought this watch in December from a very well respected watchmaker in NYC. After purchasing the watch, I noticed that it would pretty slow overnight even though it was still wound (sometimes 5 minutes). I brought it back to the watchmaker to get it adjusted (1 year warranty). He tinkered with it and said it was good to go.
    One week later, the same thing started happening again. I took it back to the guy and he oiled it a little, tested it on the machine (I forget what it is called) and then said it was good to go. However, he said that I should make sure to keep it relatively well wound while wearing it. Otherwise it can run slow. He recommended that I manually wind it at night before putting it down and leaving it crown side down overnight to keep it running on time. He also recommended giving it a boost in the morning when I put it on.
    I've been trying giving it a boost in the morning and this morning, even though I wound it about 30 times, it lost over a minute in about 7 hours. I tend to be relatively stationary at work (lawyer sitting at desk), but that seems excessive.
    Can anyone give me some advice? I want to know whether I can insist that the watchmaker do a full service on the watch to make sure it works properly or if this is just something I have to live with when it comes to an early model automatic. Also, he noted that it was slightly magnetized when I brought it to him, but from looking online that only seems to make a watch run faster.
    3 Mar 2017, 4:21 a.m.
    Sounds like this watch is due for a service and this "watchmaker" is trying for a quick fix.
    8 Mar 2017, 7:29 p.m.
    It maybe that the seller is correct. If, as many do now, you spend the day working at a computer the watch wont wind and the manual wind may be needed.
    If that's not the case and it's losing time when fully wound there's a problem and the seller should either fix it properly or give you a refund.
    10 Mar 2017, 2:51 p.m.
    Hi MDL 130,,
    this really much sounds like the Watch need a proper service. The pellaton design based IWC Cal. 85 is known for its automatic winding efficiency, so even if you are not a road worker, it should wind properly and not loosing 1 minute in 7 hours. Thats ridiculous for a high grade watch as yours. Give it to a "real" watchmaker for a service. Something like giving i a little oil to fix that problem is not craftmanship but more "bungling".
