  • Rose gold Cal.89
Rose gold Cal.89
  • forum 6 replies
  • last reply by Franco 26 Apr 2025
    Pafeso
    7 Feb 2025, 6:17 a.m. 7 Feb 2025, 6:17 a.m.
    I recently got an IWC that was shown as 18kt rose gold. Looking at the caseback it's 14kt, and the finishing with the perlage isn't very good (streaky and not staggered) compared to what i've seen on comparable models (more even and staggered beautifully) along with some missing hallmarks on the caseback. And the hallmarks that are there don't match up with what i've seen (font is slightly different and edges of the top aren't rounded) The mouvement looks good and the hands look good (exept the seconds hand that's slightly bent), same with the dial. Though one of the lugs isn't straight either and there's some oxidation near the joint with the case. Also, the mouvement ring is polished and slightly domed with no stamps on it. When comparable ones are brushed with some letters stamped on it. On the caseback it looks like there was a serial number that was scratched off. What do you guys think about all this? Is it possibly an earlier model and what about it's authenticity?
    Thanks in advance for your help!
    Note: the lighting is very yellow so the gold looks much yellower than it actually is.
    Pafeso
    7 Feb 2025, 6:27 a.m. 7 Feb 2025, 6:27 a.m.
    here are some i found:
    https://vintage-portfolio.com/shop/iwc/wonderful-iwc-vintage-gold-dating-1965-cal-89/
    https://daisyexclusive.com/products/iwc-schaffhausen-18k-rose-gold-watch-caliber-89-circa-1947 This one has similar perlage, but the hallmarks arent the same at all. And mine has many missing stamps.
    thank you
    Mr. Andreas
    Insider 84 posts
    7 Feb 2025, 10:59 a.m. 7 Feb 2025, 10:59 a.m.
    Could it be one of these once?
    https://www.chrono24.com/search/index.htm?currencyId=USD&dosearch=true&manufacturerIds=124&maxAgeInDays=0&pageSize=60&redirectToSearchIndex=true&resultview=list&sortorder=0&year=1965
    Pafeso
    8 Feb 2025, 12:10 a.m. 8 Feb 2025, 12:10 a.m.
    No, i have a jumbo 36mm.
    Insider 419 posts
    8 Feb 2025, 5:42 p.m. 8 Feb 2025, 5:42 p.m.
    Hi Pafeso,
    The case does not seem original to me. The back cover should have a serial number and a probus Scafusia stamp. The combination 14 carat rose gold is also unknown to me from IWC. I fear that the case and movement do not belong together and were put together at a later date.
    br Cromagnonman
    Mr. Andreas
    Insider 84 posts
    4 Mar 2025, 10:03 a.m. 4 Mar 2025, 10:03 a.m.
    I think it is a Vintage 1960s IWC Schaffhausen 18k Roségold. Cal. 89
    Franco
    Connoisseur 215 posts
    26 Apr 2025, 7:19 p.m. 26 Apr 2025, 7:19 p.m.
    How can it be 18K.  Hallmark clearly indicates 14K.
