Home / Gallery / Setting a minute repeater
  • forum 6 replies
  • last reply by coppe 11 Sep 2017
    John Hemming
    Apprentice 4 posts
    29 Feb 2012, 4:08 p.m. 29 Feb 2012, 4:08 p.m.
    I have set my minute repeater this morning, and for some reason the chimes are circa 30 minutes out from the actual time. What do I need to do to sync the two? I seem to have mislaid my instruction manual.
    Thanks in advance for your help
    Mr.
    Apprentice 0 posts
    29 Feb 2012, 5:18 p.m. 29 Feb 2012, 5:18 p.m.
    The time in a Minute Repeater should never be turned backwards as this could lead to a mechanical failure. Time setting always and only forward.
    I'm not aware that a sinc is possible by the owner itself. Might be that you need the help from the IWC Service Team.
    Urs
    Greg Chalk
    Master 2077 posts
    29 Feb 2012, 5:28 p.m. 29 Feb 2012, 5:28 p.m.
    Are you lucky that you and I have a dealer near your doorstep in Victoria Place, but I suspect this is going to take time as this model will go back to the factory for all service and repair issues.
    Moderator 11468 posts
    29 Feb 2012, 5:33 p.m. 29 Feb 2012, 5:33 p.m.
    I'd wait a day to see if it corrects itself. If not, I'm afraid it's time for a hospital visit.
    By the way, in addition toi STZ's excellent advice I assume you know that there also should be no setting while the watch chimes.
    John Hemming
    Apprentice 4 posts
    1 Mar 2012, 3:26 a.m. 1 Mar 2012, 3:26 a.m.
    Thank you all for your sound (no pun intended) advice, looks like a trip to the service centre it is, as the watch has the same problem this morning :(
    Mr. Bertrand Lemieux
    Apprentice 5 posts
    10 Sep 2017, 3:23 p.m. 10 Sep 2017, 3:23 p.m.
    John Hemming has written:
    Assuming you took it in for service at IWC, would you be willing to disclose the cost of the service for the minute repeater at IWC?
    Mr. Zoltan Kovács
    Insider 62 posts
    11 Sep 2017, 5:23 p.m. 11 Sep 2017, 5:23 p.m.
    STZ wrote: Time setting always and only forward.
    Just to comment, I adjust time in both directions (forward & backward) on my 5240 without any problem (of course not while it chimes!).
    Although the issue which is described here may simply be the effect of some wheels whose dents are misaligned, it should indeed go back to Schaffhausen. The cost of a complete overhaul of a minute repeater is in the vicinity of a handful of ‘000 EUR... more than a lot of watches on the market, but when you love it that does not matter...
