    15 Aug 2020, 11:15 a.m.
    Hi!
    This post isn't really about my Portuguese Chronograph that I got about 12
    years ago and still love, it's about the box it came in. After all these
    years, the rubberized surface has become sticky, with dirt and dust
    practically gluing itself to it.
    It's a lovely box, so I really don't want to have to throw it out... Does
    anyone have any suggestions on how to clean it up without damaging it (like
    accidentally rubbing off the white IWC print and text)?
    Grateful in advance,
    /Jan
    15 Aug 2020, 1:52 p.m.
    I had the same problem and used a cooker grease cleaner. Spray each side of
    the box with the degreaser and let it work for about 10 minutes. Then wipe
    vigorously with a cloth. This procedure may have to be repeated several times
    until the covering is completely removed.
    After that, the box is more anthracite than black and the writing is
    completely retained.
    When this is done, clean the box well with a damp cloth.
    I am very satisfied with that work.
    Good luck trying
    17 Aug 2020, 3:22 p.m.
    That method worked great! The top and the sides are nearly perfect after the
    first run! I used the "Cillit Bang Kitchen Degreaser" (the only one I found on
    the store shelf) and, after spraying the surfaces, let it set for 10 minutes -
    just like you said!
    Though, I did try it first on a knob for a stereo receiver that had gone
    sticky in the same way, just to know what to expect.
    I'm waiting for the second run on the top of the box to do it's thing, but so
    far there is no hint of the surface becoming lighter nor has the printing
    faded!
    - Unfortunately, the felt on the bottom of the box didn't appreciate the
    treatment (even though I didn't spray the bottom). However, the bottom of a
    box isn't really all that relevant in my case (pun almost intended).
    However, I'm really glad that the contents of the box is of much higher
    quality than the box itself! :)
    Edit: As the felt wasn 't up to snuff, I decided to remove it. I found
    new print!
    My guess is
    that IWC wanted to optimize their rubber material and just covered the back
    piece with felt in order to "fix it".
    17 Aug 2020, 8:56 p.m.
    Nice to see that these boxes in such condition can be revived!
    20 Aug 2020, 2:11 p.m.
    I just thought that I'd post a photo (albeit amateurish) of the end result.
    I'm really happy with how it turned out! No yucky sticky glue-ish rubber at
    all, nor has it changed color! Thank you for the help!
