  • What is that Component?
  • forum 5 replies
  • last reply by rsheridan 26 Nov 2008
    24 Nov 2008, 11:50 a.m. 24 Nov 2008, 11:50 a.m.
    Pictured here is a movement component in the Big Pilot 5011 Calibre - this wheel (the large, orange wheel near center) with the eccentric spiral on top. What does this component do? What function does it perform?
    homepage.mac.com/rsheridan/.Public/img_bild6.jpg
    Nicky
    Master 2085 posts
    24 Nov 2008, 9:40 p.m. 24 Nov 2008, 9:40 p.m.
    Power reserve indicator spring?
    It looks like it is where the power reserve indicator sits so my guess it is a sort of spring that controls the power reserve's 7 day indicator? And by the looks of it it also keeps it in place.
    Actually this is starting me guessing and now you have me want ing a book on movements to understand it better ;-)
    Master 1963 posts
    24 Nov 2008, 5:10 p.m. 24 Nov 2008, 5:10 p.m.
    It appears to function as part of the advancement of the date ring. I'm not sure, however, if it is actually resposible for the "rapid-advance" function.
    René Schipper
    Connoisseur 128 posts
    25 Nov 2008, 4:05 a.m. 25 Nov 2008, 4:05 a.m.
    I also think is the rapid date shift(nt)
    25 Nov 2008, 2:55 a.m. 25 Nov 2008, 2:55 a.m.
    Me three...
    I am wearing my 5001 today and took it apart to verify ;-)
    No, seriously I did hold the watch in the position as pictured above and was looking at how it works. I guess the tension builds until the edge on the left of the center-part of the spring forces the outer triangle up, creating enough momentum to make the date shift.
    26 Nov 2008, 2:30 a.m. 26 Nov 2008, 2:30 a.m.
    Yes - it's the date display mechanism...
    As the 24-hour wheel (the large, gold wheel with the eccentric spiral on top) turns toward midnight - the large teeth at the outer, white date disc interface - to advance the date. You can see the "white" spring arm at lower-9'oclock in the image - that will ensure a "snap" and proper centered position of the new date in the date window on the dial.
